Browse Forums DIY, Home Maintenance & Repair 1 Jun 08, 2025 2:35 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Water is entering my laundry from outside. The builder replaced the door seals but it continued and the architraves were water damaged. I have removed the architraves to repair the damage. Please refer to pic What can I do to repair this please? Building with Long Island Homes 23sq custom build 2017 Re: Cause of water entering laundry through door? 3Jun 09, 2025 2:51 pm Is this a new build? No, it’s 7 years old Building with Long Island Homes 23sq custom build 2017 Re: Cause of water entering laundry through door? 5Jun 10, 2025 2:47 pm And it only happens when it rains? Yes, with heavy rail fall No pooling of water outside though Building with Long Island Homes 23sq custom build 2017 Re: Cause of water entering laundry through door? 6Jun 13, 2025 9:30 am im not convinced that its coming through the door. But aside from that I cant help anymore, you need to buy a moisture tester to trouble shoot it yourself or seek professional advice. long term solution is to regularly use barrier spray outside your home 1 59764 Yeah, that’s a pretty common issue with older suburbs. If you’re going the private pole route, make sure your LV2 electrician checks clearance and Ausnet’s… 2 70897 |
