Browse Forums DIY, Home Maintenance & Repair 1 Jan 12, 2007 9:40 pm I have a cottage with a kitchen in a sixties extension. On an outside wall there is mold up to about a foot from the floor and about 3 - 4 feet across. I have found that the other side of the wall in a neighbours property is rendered and at the same height the render is broken leaving large gaps. I assume rainwater is getting in and being soaked up by the brickwork and ultimately causing the mold, probably helped by the kitchen environment. I am arranging to have the render repaired. Would it be reasonable to treat the inside and repaint and leave it to dry out or would it be better to replace the affected plaster which is in good condition?
Thanks Re: rendering 2Jan 13, 2007 5:08 pm If the plaster has had constant damp/water its probably had it. I'd replace it once the source of the problem is fixed. Are you sure the mould isn't from 'rising damp'? Re: rendering 3Jan 14, 2007 3:23 am I don't think it's rising damp. The render on the other side of the wall has broken away at exactly the same place as mold is appearing on the inside and there is no problem either side. Anyway, hanks for your reply. I'll probably have the plaster replaced. Re: rendering 4Jul 11, 2007 5:59 pm Fix the outside and leave it to dry thoroughly before painting inside.
Otherwise, if there any moisture is left in the wall it will try to go through the paint work and you can ad up with pilling wall. Re: rendering 5Mar 18, 2009 8:05 pm Rising or falling damp...IMHO
Says he the waterproofing contractor ![]() DIY, Home Maintenance & Repair Unless you have a damp issue, either failed waterproofing in a wet area, a leaking pipe or rising damp, moisture shouldn't be an issue. You can usually tell if you have… 5 8222 ![]() Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 1639 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 1853 |
