Browse Forums DIY, Home Maintenance & Repair 1 Nov 30, 2024 11:37 am Re: Rust on Steel Post 2Nov 30, 2024 12:55 pm You need to remove the concrete pavement to see the full extent of rust. Depending on the loss of section amount, you can sand/clean and cold gal or you replace the post. Make sure the concrete pavement slope away from post to allow for drainage. Re: Rust on Steel Post 3Feb 13, 2025 5:25 pm ![]() You need to remove the concrete pavement to see the full extent of rust. Depending on the loss of section amount, you can sand/clean and cold gal or you replace the post. Make sure the concrete pavement slope away from post to allow for drainage. When you sand off the rust, you MUST get rid of ALL of the rust, before Cold Galvanise painting This is a Metallurgy Graduate speaking Otherwise you are only slightly delaying the inevitable. thanks, yes they are dry , thats a good idea with fish oil as sanding will be hard 4 21983 I have an outdoor verandah where a tile joint along a galvanised steel bracket to a post has started weeping rust. Looking to… 0 20199 2 12287 |
