Browse Forums DIY, Home Maintenance & Repair 1 Sep 08, 2024 7:51 am Hi Team, I have an electric gate opener which has been misbehaving. It is about 10 years old, has battery backup, and is sitting on a concrete pad. The symptom is that when I try to open it (by remote or by pressing the OCD button) I hear a click, but the gate (sometimes) doesn't move. At first I thought this was a remote control issue, but the fact I have the same problem regardless of how I fire the gate means I've ruled that out. Then I noticed the concrete pad was a little loose, and I wonder if the problem is that. I tried to test this by stabilising the pad with a big clamp, but the same problem. I assume my batteries are well passed their use-by date, but I assume that isn't a problem. Short of giving it a good clean and removing the batteries, is there anything else I should be checking for? Seems silly to replace without trying to fix it first. Cheers, Dim DIY, Home Maintenance & Repair No. Only the one upstream from the one that overflows. It doesn't overflow. It was an addition I added to try to solve this ones overflowing. But, it did not change… 14 6311 My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and… 0 11150 Hello all, After some recommendations for Brisbane or SE Qld companies who do electric sliding gates. I have no idea what my limitations are (block width is 15 metres… 0 6170 |
