Browse Forums DIY, Home Maintenance & Repair 1 Aug 26, 2024 6:11 pm Hi, thought I'd repaint the inside of my house as the paint is cracking in some areas and comes off easily in some spots but other spots require a little more effort. After reading through these forums it seems my plaster wasn't sealed before it was painted? Any ideas of the best way to remove the paint to seal it? Or can I just get the easier bits off and paint sealer binder over the top? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with interior wall paint (PERTH) 2Feb 13, 2025 5:37 pm How old is the house? If 1950’s or older, it could be that you have Kalsomine, and modern oil or latex paints just will not stick to it, and “Sealer/ Binders “ seem to mostly promise what they can’t deliver. Steel wool, Scotch-Brite, scrubbing brush, hot water lots of rags, lots of messes, and a do-or-die attitude is the only certain cure…. It’s a bit like cancer, prior to chemotherapy . . . . You never seem to be able to “get it all” DIY, Home Maintenance & Repair Blistering paint in your newly painted bathroom stinks! It's likely due to trapped moisture. Bathrooms are humid, and if moisture gets between the paint and the wall,… 1 20774 ![]() Hi Everyone, We recently bought a house and we want to remove a bedroom wall, now the typical question comes : is this wall a bearing wall? I think it is not, I… 0 12700 0 22640 |
