Browse Forums DIY, Home Maintenance & Repair 1 May 27, 2024 11:29 am Hi! I need help. It's been 2 days since I experienced some leaking in my kitchen. I live in some what 90's style crib and I am aware that some pipes might be brittle. However, I can't seem to locate where the leak is. I just noticed that my kitchen floor starting to get floody and a little smelly. Any possible DIY solution to this? or if the problem got worse, would there any be other suggestions? I am also concern for possible tearing of my floor if they're gonna check all the pipes. Any suggested hacks or tips in repairing floors? Re: Can't seem to find the solution for this kitchen leaking 2May 27, 2024 12:17 pm You are asking about regulated plumbing work that needs attention due to neglect. You need to contact a plumber. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Can't seem to find the solution for this kitchen leaking 3May 27, 2024 1:01 pm ![]() You are asking about regulated plumbing work that needs attention due to neglect. You need to contact a plumber. More likely mate. Do I need to change all the pipes or is it optional? Re: Can't seem to find the solution for this kitchen leaking 4May 27, 2024 1:02 pm ![]() Hi! I need help. It's been 2 days since I experienced some leaking in my kitchen. I live in some what 90's style crib and I am aware that some pipes might be brittle. However, I can't seem to locate where the leak is. I just noticed that my kitchen floor starting to get floody and a little smelly. Any possible DIY solution to this? or if the problem got worse, would there any be other suggestions? I am also concern for possible tearing of my floor if they're gonna check all the pipes. Any suggested hacks or tips in repairing floors? It sounds like you've got a tricky situation on your hands with that kitchen leak. Given the age of your place, it's not uncommon for pipes to act up. Since you're unsure where it's coming from, your best bet is to start with the usual suspects: under the sink, around appliances, and any visible signs of water damage on the walls or ceiling. If you're not having luck finding the culprit, it might be time to call in the Sydney plumbing experts. They've got the know-how and tools to track down the source of the leak and fix it without causing too much disruption. Now, about your kitchen floor worries—understandable. Nobody wants their floor torn up unnecessarily. When you call in the experts, they'll do their best to minimise any damage. They might even use fancy gadgets to locate the leak without tearing up your floor. In the meantime, you can try some temporary fixes like placing towels or buckets to catch the water and prevent further damage. But remember, these are just stopgaps. Getting professional help sooner rather than later is your best bet to nip this problem in the bud. Our plumbers deliver a same-day service, every single time. Re: Can't seem to find the solution for this kitchen leaking 5May 27, 2024 3:37 pm ![]() Do I need to change all the pipes or is it optional? That depends on the diagnosis. My first step before calling a plumber would be to hire a moisture meter, I think Kennards have them, and see if you can identify a leak source. Do you have any flexi hoses? If so, you need to immediately examine them. These won't be (or at least shouldn't be) in the walls, they will be in the kitchen cabinet. Locating leaks is often difficult because the pipes are inside walls and investigation is required. Sometimes the source can be the roof. Regardless, I would still get 3 quotes or at least an agreed hourly rate up front. Also steer well clear of Jims and Metropolitan Plumbng. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Can't seem to find the solution for this kitchen leaking 6May 27, 2024 3:52 pm ![]() ![]() Hi! I need help. It's been 2 days since I experienced some leaking in my kitchen. I live in some what 90's style crib and I am aware that some pipes might be brittle. However, I can't seem to locate where the leak is. I just noticed that my kitchen floor starting to get floody and a little smelly. Any possible DIY solution to this? or if the problem got worse, would there any be other suggestions? I am also concern for possible tearing of my floor if they're gonna check all the pipes. Any suggested hacks or tips in repairing floors? It sounds like you've got a tricky situation on your hands with that kitchen leak. Given the age of your place, it's not uncommon for pipes to act up. Since you're unsure where it's coming from, your best bet is to start with the usual suspects: under the sink, around appliances, and any visible signs of water damage on the walls or ceiling. If you're not having luck finding the culprit, it might be time to call in the Sydney plumbing experts. They've got the know-how and tools to track down the source of the leak and fix it without causing too much disruption. Now, about your kitchen floor worries—understandable. Nobody wants their floor torn up unnecessarily. When you call in the experts, they'll do their best to minimise any damage. They might even use fancy gadgets to locate the leak without tearing up your floor. In the meantime, you can try some temporary fixes like placing towels or buckets to catch the water and prevent further damage. But remember, these are just stopgaps. Getting professional help sooner rather than later is your best bet to nip this problem in the bud. Hi! I tried to use the sinks, but not a drop of water was seen. Could it be a burst pipe? and if a possible plumber is needed, how many hours does it take for this situation to be fixed? Re: Can't seem to find the solution for this kitchen leaking 7May 27, 2024 4:00 pm ![]() ![]() Do I need to change all the pipes or is it optional? That depends on the diagnosis. My first step before calling a plumber would be to hire a moisture meter, I think Kennards have them, and see if you can identify a leak source. Do you have any flexi hoses? If so, you need to immediately examine them. These won't be (or at least shouldn't be) in the walls, they will be in the kitchen cabinet. Locating leaks is often difficult because the pipes are inside walls and investigation is required. Sometimes the source can be the roof. Regardless, I would still get 3 quotes or at least an agreed hourly rate up front. Also steer well clear of Jims and Metropolitan Plumbng. Thank you for these tips! I'll check if there are any. Kinda a bit having trouble here, and it somehow made a bit cranky. I reckon where these recommended service companies are located? Re: Can't seem to find the solution for this kitchen leaking 8May 27, 2024 5:05 pm Get some food dye and pour it down sink, it should leave a trace if the leak is from a waste pipe Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 6707 Hi We are building in the Hunter Valley, our soil test is H1, our builder has advised us they need to have a letter signed for Fair Trading as the new drainage standard… 0 3829 Sorry! I'm new to this forum and have made a mistake in my posting! I'm looking for a structural solution to a stand alone wooden pickets fence with no structural rail… 1 3569 |
