Browse Forums DIY, Home Maintenance & Repair 1 Apr 16, 2024 11:03 am Re: Brick work cracks 2Apr 16, 2024 6:06 pm could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the wall to leave 10mm expansion. The bricklaying itself looks spot on ![]() Re: Brick work cracks 3Jul 04, 2024 8:21 pm ![]() could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the wall to leave 10mm expansion. The bricklaying itself looks spot on ![]() Did you mean brick mesh as in reinforcement? What was sticky back foam? Cheers Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 2564 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 7603 |
