Browse Forums DIY, Home Maintenance & Repair 1 Dec 03, 2023 12:14 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi skillaroos Hope someone can assist, thank you This sliding door to the bathroom is noisy and has become hard to slide . I am planning to replace the roller wheels . Wondering how to remove this door ? Tried sliding it off - yet no luck Is there anything I need to unscrew before it comes off the railing ? Thanks Dani Re: Sliding door to bathroom noisy 2Dec 03, 2023 2:13 pm Along the top there are 2 trim pieces either side of the track (you can see them in the last picture). You need to remove one of those. That then gives you access to the rollers so you can remove the door. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Sliding door to bathroom noisy 3Dec 03, 2023 2:28 pm chippy Along the top there are 2 trim pieces either side of the track (you can see them in the last picture). You need to remove one of those. That then gives you access to the rollers so you can remove the door. Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. It may be a sill rebate so that your bottom bricks support the door frame. Check with builder thiugh 2 2483 DIY, Home Maintenance & Repair It looks like they have used rigid sealant in the gap. You are supposed to use flexible sealants in filling this gap to allow for expansion and contraction movement… 1 995 |
