Browse Forums DIY, Home Maintenance & Repair 1 Jul 25, 2023 7:13 pm At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the 15 years since they have started to peel off and break apart in brittle little flakes. Removing the flaky pieces is easy enough but we can't find a way to remove the intact segments that are still adhering to the cabinets. Have tried the usual heat gun/wood scraper combo and some chemical adhesive removers with no luck. All advice and input appreciated. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Peeling plastic laminate - advice on removal? 2Jul 25, 2024 3:21 pm did you manage to solve this? iām having the same problem Re: Peeling plastic laminate - advice on removal? 3Jul 25, 2024 6:18 pm Afraid not mate. If you figure out a solution let me know. DIY, Home Maintenance & Repair Peeling paint on your house exterior, whether it's siding, stucco, or another material, can stem from several factors. Common… 1 8430 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 25434 Hi, I need a caveat removal that I placed on a property in Melbourne during a separation, I live in NZ and cannot get to a Post Office to verify my ID (none outside of… 0 9057 |
