Browse Forums DIY, Home Maintenance & Repair Re: Damages caused by tree 3Jul 13, 2023 1:46 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Damages caused by tree 5Jul 14, 2023 1:03 pm ![]() ![]() Hi Neighbours tree since cut down however caused damage to double brick outbuilding (bricks separated with slight lean to a portion of wall); dwarf retaining wall collapsed as roots of tree moved into our property, rotted lower portion of lapped & capped timber fence, roots grew under cemented pavers lifting them upwards, another wall of same building acts as boundary fence against which neighbours soil packed from building footings up to approx 800m, after heavy rains water/moisture found inside the building along wall acting as boundary fence. Received engineer report on how to fix however need to know which type of builder to contact to repair all damages (boundary wall, dwarf retaining wall, leaning wall with separated bricks & fence). Thank you if you are able to advise. your engineer would be able to advise you and even perhaps point you to somone whos work they /know and trust> thats a good place to start Thank you. While i was across this behavior's pre appointing my (the builders) surveyor, I did tell the builder i was aware what they were doing and while i disagreed with it, they… 13 16155 Building consultants who do inspections do not do forensic storm water and sewer pipe inspections. This is something that needs to arrange separately at PCI. This forum… 4 105 ![]() Building Standards; Getting It Right! I found https://treenet.org/resource/tree-prote ... -it-right/ which states if tpz encroachment is greater than 30% then do not proceed. My question then is, is this… 1 1075 |
