Browse Forums DIY, Home Maintenance & Repair 1 Jan 18, 2023 10:21 pm I've gone under my house to see if I can find the cause of the high moisture in our home. While crawling around in the damp ground, I came across copper pipes and noticed blue/green corrosion(?) where it goes into the ground underneath the concrete slab. The front of the house is on piers, while the back has been extended on a concrete slab. The two pipes on the left are for water and the right is for gas. When I touch the ground/dirt around the pipes, the dirt crumbles easily. I've had two plumbers look at the photos (while on-site to provide quotes to troubleshoot the subfloor moisture), and they suggested to wait and see until there's a problem. Appreciate any comments or advice on cause, or if I should be looking to have this fixed / replaced before there is a problem / leak? Thanks in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 4 5165 DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 5611 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5794 |
