Browse Forums DIY, Home Maintenance & Repair Thanks for letting us know. The programmer will have a look at this later today. 2 6897 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31484 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17721 |
