Browse Forums DIY, Home Maintenance & Repair 1 Aug 05, 2022 7:04 pm Hi all, I have an issue with my building foundation where some movement seen to have occurred around the stumps. I had a few restump/releveling builder who came to check out the property and so far, all of them has said there's a moisture/wet foundation issue and two of them even said it's best not to do anything to the foundation until the ground is properly dried and the water issue rectified. I'm fairly new to anything home improvement wise, so just wondering what sort of roles should I be looking for to investigate and fix the issue of moisture/water around foundation? Plumbers would do the trick? I'm not sure if its due to rain or something else at this stage. Any tips on how to go about investigating something like this would be great too. Re: Wet/Moisture issue around foundation stumps. 2Aug 05, 2022 7:10 pm First get a plumber to check for leaks if they are found then it could be an insurance claim depending on the situation. Re: Wet/Moisture issue around foundation stumps. 3Aug 29, 2022 8:36 am Hi Twon069
Yes get your pipes checked for leaks. Also check for water ingress during heavy rains. If you're house is on any level of reactive clay then yes your re-stumping guys are wise to wait until the ground moisture levels have stabilised or it'll all just move again. How do you know the ground moisture levels have stabilised? Regularly testing the soil moisture in a few key locations will provide those answers and may also help establish the source of the water. Google slab heave foundation monitoring for some more info. There's a great smart sensor solution available now Cheers. Rob. Re: Wet/Moisture issue around foundation stumps. 4Aug 29, 2022 11:41 am SLABsense I think blatant self promotion is against the rules here. It certainly is. You have a good product (I remember the topic that you first commented on). People need to know about your product, why not sign up as an advertiser which will also help support the forum? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Wet/Moisture issue around foundation stumps. 5Aug 29, 2022 1:34 pm SaveH2O SLABsense I think blatant self promotion is against the rules here. It certainly is. You have a good product (I remember the topic that you first commented on). People need to know about your product, why not sign up as an advertiser which will also help support the forum? Thanks Yes I've looked into sponsorship and it's 100% on my road map. I'm focusing on development of our second product atm and then some proper marketing and launch activities will kick in. I'm not advertising yet and just trying to help where I can without being too salesy on places like this (eek). I'll edit my comment a bit to make it less direct. Re: Wet/Moisture issue around foundation stumps. 6Aug 29, 2022 2:39 pm Experienced building consultant should be able to help you Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Wet/Moisture issue around foundation stumps. 7Aug 29, 2022 8:32 pm SLABsense I'm focusing on development of our second product atm and then some proper marketing and launch activities will kick in. I'm intrigued. Is it also in the geotechnical realm? A good video can have several avenues to engender awareness. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Wet/Moisture issue around foundation stumps. 8Aug 30, 2022 8:06 am SaveH2O SLABsense I'm focusing on development of our second product atm and then some proper marketing and launch activities will kick in. I'm intrigued. Is it also in the geotechnical realm? A good video can have several avenues to engender awareness. It's in the Slab Heave monitoring space but not geotechnical. There's a sneak peek on the website under the Forensic Structural Engineers page if you're interested. Re: Wet/Moisture issue around foundation stumps. 9Dec 11, 2022 9:35 pm Hey all, Sorry for the super late response (and necroing the thread) Just want to give an update. It turns out to be storm water which flows from one side of my properly directly down into the foundation. I ended up getting a plumber to install perimeter agi drainage as well as some surface drainage (there were none), but that turned out to be a disaster... The outcome made it worse and I ended up getting an inspector to do a report on the drainage and went through a whole back and forth to get a refund on the whole thing... I'm sort of back at square one (or 1.5) but I have a rough idea of redirecting the waters away from my foundation. But it also opened up a whole can of worm where I'm contemplating on ripping out the old concrete driveway and redo it with proper surface drainage. DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 9013 these look like missing batts. Go up and take a look. But yeah moisure meter is a completely different tool 4 9477 |
