Browse Forums DIY, Home Maintenance & Repair 1 Apr 16, 2022 8:12 pm The water mains pipe has broken at the connection from the water meter going to my house. I have dug up the pipe just after the water meter in preparation for a plumber to come and have a look and I am wondering how much trouble I am in. The pipe connection right where it connects to the meter is stuffed, that much is obvious, but after digging a little more out I have uncovered the pipe more, I am just wondering if this is how copper pipes normally look after minimum 10 years (how long I have been here) of being underground or will the entire line need replacing. We have had no water pressure issues until now. As I said, where the pipe connects to the water meter is the obvious breakage. In the photo, where the white plumber tape is, is not connected to the water meter anymore. And also, if it needs replacing entirely are there temporary measures I can take to ensure I have water in the house while I dig up the yard enough to lay a new line? This would take me days to do and it will have already been 5 days of no water because of the Easter long weekend by the time a plumber arrives. I came across this website with a few pictures and it got me wondering about temporary solutions. The blue hose is the kind of thing I am wondering about. https://inspectapedia.com/plumbing/Plastic_v_Copper.php Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Water mains pipe needs replacing. 2Apr 17, 2022 10:09 am That looks like corrosion on that pipe so it may not be copper which would be odd. Plastic is the norm post meter nowadays but temporary repairs by someone who is not a licenced plumber are a definite no no. if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4312 DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 5946 2 8499 |
