Browse Forums DIY, Home Maintenance & Repair 1 Jan 06, 2022 8:02 pm Apologies , if similar to this has previously been discussed. I have recently had repairs done to 2 x in ground rainwater tanks. This required cutting of the existing 100mm DWV pipe coming from house drainpipes to both tanks. 2 x DEKS 100mm Dek rubber joiners were installed in a movement repair to the pipe close to the inlet , about 3 years ago , this joiner is in the ground so unseen. After repairs to tanks I reinstated the pipe work with an addition of a glued slip coupling applied to where the pipe was removed for earthworks. I would say I never applied all the rules with this joiner i.e. twist once glue has been applied to both joining surfaces etc. I now have a small drip as this part of the system is water charged and probably the lowest point in the pipe ,so water stays there even during dry weather , whereas the original couplings are further down and only have water flowing past (not charged). Is it possible to use a DEKS coupling in this situation , planning on using 4 SS clamps not just the two. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks in advance. Re: Joining 100MM Charged DWV System 2Jul 07, 2022 10:19 am Have only just seen this thread. No doubt you have already fixed the leak but the DEKS coupling would be fine to use. You probably had a bit of grit or similar on one of the surfaces. I assume you never used primer which should always be used on a charged pipe plus a quick twist on the pipe when inserting into the fitting is always best as you mentioned. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19517 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9793 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14045 |
