Browse Forums DIY, Home Maintenance & Repair 1 Sep 09, 2021 10:20 am I've noticed on some of my walls, that the plasterboard feels disconnected from the stud, in that I am able to press on a particular spot and feel a gap before it presses against the stud. This becomes most noticeable on a windy day when I can hear the plasterboard 'flex'. Subtle creaking and cracking noise that I only notice on those walls where the plasterboard is loose. I've seen a suggestion on screwing the wall back onto the studs to secure them. Is this recommended? And are there particular tools and practices that I should follow? My studs are steel frame btw. Cheers! Re: Plasterboard loose from stud 2Sep 27, 2021 4:51 am basKT_case I've noticed on some of my walls, that the plasterboard feels disconnected from the stud, in that I am able to press on a particular spot and feel a gap before it presses against the stud. This becomes most noticeable on a windy day when I can hear the plasterboard 'flex'. Subtle creaking and cracking noise that I only notice on those walls where the plasterboard is loose. I've seen a suggestion on screwing the wall back onto the studs to secure them. Is this recommended? And are there particular tools and practices that I should follow? My studs are steel frame btw. Cheers! A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️ 2 11478 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 10585 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 4630 |
