Browse Forums DIY, Home Maintenance & Repair 1 Sep 07, 2021 5:14 pm Hi, I hope this is the right place, it's my first post. I have laminated timber flooring and have always found it a challenge to maintain. One issue I noticed, when I moved my TV Cabinet, was pink squares from underneath the cabinet legs. I don't use much water on my floors, only a spray mop. I don't use any harsh detergents either as I know that can cause damage. Any idea what might cause this? I've done a lot of research, but I'm unsure what to do from here. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks, hmmm id assume youll get hit with the "natural product therefore variation in colour etc" excuse. How bad are we talking? One could argue that if none of the displays or… 3 2448 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15886 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3271 |
