Browse Forums DIY, Home Maintenance & Repair 1 Aug 09, 2021 12:09 pm Hello, While clearing out my severely blocked weep holes (caked with mud and mortar debris), I have accidentally poked a tiny hole in the material that is on the other end of one of the holes. I think the material could be the flashing. I used a number of items to prod, dig, and scrape, and it was the end of a wire hangar that made a hole. The hole is small, just the diameter of a hangar wire. I don't know how deep it goes, just that the surface of the material now has a puncture. I'm almost certain the material is this embossed polythene dampcourse: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What can I do to patch up the hole? Obviously, access is very limited being such a small weep hole entrance, and I would rather not have to go to drastic measures like removing the surround bricks. Cheers! I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 2971 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 3614 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 8559 |
