Browse Forums DIY, Home Maintenance & Repair 1 Jul 27, 2021 10:23 am Hi guys, I've just moved into a new place, and while we were removing the old laminate flooring in the master bedroom to get ready for carpeting, we discovered evidence of water damage on the bottom of the door frame leading to the en suite. Fortunately it seems like the damage was done a long time ago and the issue now solved (the wall directly behind the shower taps looks to have been cut open and then re plastered, hopefully to access and fix the leak). I have scrapped away most of the loose rot and old sealant leaving what you see now in the images below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We intend to repaint the skirting boards and architraves and wanted to get your opinion on how we should treat the damaged wood before we start. I have seen other mentions of using a wood hardener. Will this be sufficient? Anything else we should do to prepare it for painting? Cheers! I thought this would be a popular question but I haven't been able to find any similar posts. Perhaps I'm wording my searches wrong? When you have car insurance and the… 0 6624 there was an event. The question is whether the builder had the insurance and whether the event was covered. The workmanship is a separate conversation. 10 23779 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8057 |
