Browse Forums DIY, Home Maintenance & Repair 1 Jul 23, 2021 6:23 pm Hi all, I have discovered one of my roof tiles (terracotta) has a cracked edge. Please see picture. I’m wondering how will I be able to relate this? I know changing it would be the answer but it it is sitting just 1 down from the ridge capping. The tile in question is on the first row horizontal to the gutter. As you can see the hole can take in water and is just over the eaves. I’m sure there is a way to fix. Not worried about the look as it’s out of the way. Was thinking of getting a small piece of older tile, placing it in the gap as close as possible and using tile sealer. Any help would be great. Thanks Mick [img:vphljlbp]https://forum.homeone.com.au/u/1_1627028548.jpeg[/img:vphljlbp] Re: Cracked Roof Tile Repair 2Jul 23, 2021 8:04 pm If you still have the piece that broke out, just silicon it back. Be liberal with the silicon in the joint and smooth it over the crack to fill any bits that may have been lost. If you can lift the tile above it a little bit you could get some sheet lead that you tuck under the tile above and flash down over the broken bit. The sheet lead can then be formed over the tile shape and stays in place. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Cracked Roof Tile Repair 3Jul 23, 2021 8:28 pm chippy If you still have the piece that broke out, just silicon it back. Be liberal with the silicon in the joint and smooth it over the crack to fill any bits that may have been lost. If you can lift the tile above it a little bit you could get some sheet lead that you tuck under the tile above and flash down over the broken bit. The sheet lead can then be formed over the tile shape and stays in place. Thanks for the reply. I don’t have the piece, I found it like that. We just bought the home. Was thinking of breaking another piece similar and then sealing all over it with tile silicone. Think that should be ok? 8 4920 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 8892 |
