Browse Forums DIY, Home Maintenance & Repair 1 Jun 13, 2021 8:45 pm Hi This afternoon I bought a non-working GMC air compressor for $20. The model is a GMC AC24L I believe (will check tomorrow in the daylight). I'm pretty sure it needs a regulator of some sort, like this - https://www.ebay.com.au/itm/154401454221 AND a small piece of copper pipe, something like this - https://www.aliexpress.com/item/1005002308652687.html BUT before I do all that, I will check that the compressor actually turns over. It may be seized for all I know. I was told it was working previously. Can anyone offer advice? Get it going or chuck it? Re: GMC air compressor parts 2Jun 13, 2021 10:53 pm I bought a GMC compressor in 2006 for about $100. Worked well enough for my DIY jobs (Probably but in 2,000-3,000 nails + other bits and pieces before it broke) I put in 1,000 nails in a morning building a deck so that paid me back I replaced it with a similar unit which I bought (before GMC went bust) which I have still got. If that gives up the ghost I would be down to bunnings to buy a Ryobi unit which I see are selling for $129. I would never buy a 2nd hand unit as I would be worried about corrosion on th einside of the air tank. . . . not everyone drains the tank every tme they use the unit. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3721 I need to replace some lengths of aluminum shower frame but I can't seem to find any suppliers of this stuff. Neither the blue or orange home centers carry these things.… 0 5432 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6047 |
