Browse Forums DIY, Home Maintenance & Repair 1 May 02, 2021 10:41 am Hi everyone, I think my subject heading probably explains my issue already! I've done a little online research and there are so many different methods recommended it's hard to know which one to use! I would appreciate greatly some help from somebody with a little know-how who can recommend a simple, effective method. At the time of writing, the stain is only a day old. Many thanks in advance to anyone who can help! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Remove small, light carpet stain from printer ink cartri 2May 02, 2021 10:59 am Try pure isopropyl alcohol but read this first. https://forums.whirlpool.net.au/thread/35qqwvr3 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Remove small, light carpet stain from printer ink cartri 3May 02, 2021 11:04 am SaveH2O Try pure isopropyl alcohol but read this first. https://forums.whirlpool.net.au/thread/35qqwvr3 Thanks very much, SaveH2O. Re: Remove small, light carpet stain from printer ink cartri 4May 02, 2021 11:22 am You're welcome and welcome to the forum. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Remove small, light carpet stain from printer ink cartri 5May 07, 2021 6:02 pm Use regular soda water, salt, and baking soda. Using a damp rag, wipe away the excess mess. Next, pour in half a cup of soda water After that, combine 5 teaspoons baking soda and the same amount of table salt. Combine the ingredients, rub them into the stain, and set aside for 5–10 minutes. To get rid of the excess, use a vacuum cleaner. Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6700 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 3633 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5900 |
