Browse Forums DIY, Home Maintenance & Repair 1 Feb 23, 2021 1:50 pm Hi. There are 2 questions: 1. There are 2 vertical pipes in 2 corners on the house (see photos). They start underground and reach roof support beams. Galvanised steel. Dimensions about 50mm by 75mm. What is their purpose? Are they support roof? Or they hold house from shifting sideways in case of strong wind? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I suspect they are rusty underground, should I take it seriously and do something about it? 2. Current stumps were made from hardwood. They are rotten and eaten by termites. The house is not level. I am going to re-stump the house. Will use steel "Uni-Pier" from Bunnings. https://www.bunnings.com.au/uni-pier-65 ... m_p0136043 https://www.bunnings.com.au/uni-pier-75 ... m_p0136116 Questions: - 65mm or 75mm - any difference but price? In which cases I need 75mm? Location on the property in South Perth, according to Wind Map it is "low risk" zone. Area flat. There is housing around. Soil: sand. - what kind of "foundation" I need for the stumps? I assume it should be concrete and there must be 2 bolts to secure the stump to the foundation, but I cannot find guidance with recommended dimensions: how deep it should go, surface it should cover. Only one information I found: the stump must be at least 100mm above the ground. So I know how HIGH the foundation must be. Anyone can assist with some guide/standard? Are they stumps or screw piles ? How much fill is there, is the site a class "P" ? A "H2" site is not supposed to have stumps it is supposed to have grid beams according… 1 6958 If you're in a flood zone, not only are you dealing with the importation of fill and laying it down in 150 lifts to achieve compaction, you're going to have to consider… 4 5537 Hi VK, Think it's worth investing time in an Owner Builder course to equip you with basic knowledge on Australian Building Industry and its regulations. Also, I suggest… 11 23744 |
