Browse Forums DIY, Home Maintenance & Repair 1 Jan 18, 2021 2:10 pm Re: How to fill gap Between House and concrete 2Jan 18, 2021 4:14 pm I've used sikaflex 11fc. Works a treat. If you do some googling you can find it relatively cheap (18 bucks or so per 600ml sausage instead of the Bunnings 25 bucks per 300ml cartridge). That bitumen impregnated tape has a removable top section, tear that off (should come out easy) and fill the gap with the sikaflex. If there is too much of a void in places you can use foam gap filler rod before you sikaflex it. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. 2 7524 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17546 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9143 |
