Browse Forums DIY, Home Maintenance & Repair 1 Dec 02, 2020 3:06 pm Hi All, I am a first time home owner of a unit. Took over the property from a family member and have very little experience with home maintanance. My Ceiling paint has started to peel away in one particular area after a repaint. I have spoken to Strata about finding the cause of the issue but all that aside i was looking for some advice on repainting. I would prefer not to repaint the entire place. Is it possible to use painters tape to tape off the cornices where they meet the ceiling, as well as the bottom of the stair case (outlined roughly in red) and just sand away the paint on the celing of the room and repaint? Any advice woud be greatly appreciated. Cheers! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Repainting Ceiling 2Dec 02, 2020 3:26 pm You don't even need to mask it up, you can just cut in to the edge of the cornice and along the change in the ceiling. It will be hard to pick the change in paint at those points. But before you paint you have to find out why the original paint is coming off or it will just peel away again, it may even take more off. Depending on what sort of ceiling it is there could be many reasons, from no sealer to moisture or other reasons. Any loose paint will have to be scrapped off and the areas filled and sanded. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Repainting Ceiling 3Dec 03, 2020 11:37 am Thanks so much for your quick reply! I will definately find out the root cause before repainting. Honestly a major help with the repainting tips though, many thanks! How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5936 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2452 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17198 |
