Browse Forums DIY, Home Maintenance & Repair 1 Sep 27, 2020 9:08 pm This retaining wall is almost 2m high, it’s behind the house with a concrete slab between it and the house. Every now and then with water build up from heavy rain, it’ll seep out and cause light flooding just behind the house on the concrete slab. There’s no where for it go, so it either dries or I basically sweep it away to the side Any advice to deal with this? Obviously cutting the concrete slab to make a drain isn’t ideal. Not sure how I can redirect it without tiling it or cutting concrete. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5179 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16122 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6900 |
