Browse Forums DIY, Home Maintenance & Repair 1 Oct 10, 2010 9:29 pm Does anyone know if colourbond can be patched up? Our newly installed colourbond watertank in monument is sporting a large scrape. We are near salt water so having metal exposed is a concern but so is a patch up job that is *. I'm at a loss as to why tradies are not more careful when installing their products. Our new polyurethane kitchen along with our laminated media unit were installed sporting nicks and scratches. Not happy Jan! Re: Damaged Colourbond Watertank 2Oct 11, 2010 5:48 pm There is touch up paint available from plumbing suppliers. I wouldn't let them touch it up for 2 reasons: 1. it fades at a different rate to colourbond 2. Bluescope the manufacturer does not recommend the use of touchup paints because of the 1st reason and as such will not warranty their product. I would be asking for a new tank, not a second hand one that has been patched up. It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2382 The coupling, which is made from flexible PVC, needs to comply with AS/NZS 4327 which specifies the requirements for metal banded flexible couplings used in low-pressure… 1 1250 Coming back to this.... When installing a pressure flashing, what fixings would you use (please give a link) ? Above Pedro said nylon anchors. Anyone have a preferred… 7 10668 |
