Browse Forums DIY, Home Maintenance & Repair Re: Where to buy cut-to-measure plywood in MEL? 3May 21, 2019 7:34 am Can't you just buy a small panel from Bunnings and get them to cut it in store? https://www.bunnings.com.au/project-panel-1200-x-600mm-18mm-bc-plywood_p0390159 Re: Where to buy cut-to-measure plywood in MEL? 4May 21, 2019 10:15 am brokenstick Can't you just buy a small panel from Bunnings and get them to cut it in store? https://www.bunnings.com.au/project-panel-1200-x-600mm-18mm-bc-plywood_p0390159 I've not come across a Bunnings that would cut to size... It's really weird. In Germany pretty much every hardware store offers this service for DIYs. You can even order online and pick up the same day. Why is there no such thing in AUS? Re: Where to buy cut-to-measure plywood in MEL? 5May 21, 2019 10:42 am karcher.cc brokenstick Can't you just buy a small panel from Bunnings and get them to cut it in store? https://www.bunnings.com.au/project-panel-1200-x-600mm-18mm-bc-plywood_p0390159 I've not come across a Bunnings that would cut to size... It's really weird. In Germany pretty much every hardware store offers this service for DIYs. You can even order online and pick up the same day. Why is there no such thing in AUS? I often used to get stuff cut at Bunnings, but I think not all stores did it. They were meant to charge $1 a cut, but often didn't bother. Maybe they have stopped? My local Mitre10 cuts as well Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4073 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10247 Fine with me... just let 'em step in with some affordable (but good) gear... 12 5497 |
