Browse Forums DIY, Home Maintenance & Repair Re: Rheem solar hot water long roof sensor replacement 6Apr 18, 2019 10:59 pm The part will post to you easily. I like their video guides, most informative. We had a real good run with our Rheem solar installation. Replaced the ground based tank once and a couple of pressure-release valves on the roof collectors. Only replaced it when gas came to our area and we went with an instant gas system. I'm curious, did they provide any reason why they did not like the idea? 1 14038 We're looking at replacing the roof of a heritage listed home so it needs to be terracotta tiles, wondering if anyone has any recommendations, hints or… 0 1378 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13918 |
