Browse Forums DIY, Home Maintenance & Repair 1 May 13, 2017 11:17 am Hi Guys and Gals.
I have a great Underground water tank. It has a pump to access water. We have been away and I've noticed a ticking - like a clock coming from the pump electrical area. Any ideas on what it might be - is it a common thing ? Re: Pump - Underground Water Tank - Noises ? 2May 13, 2017 11:18 am I've noticed it can stop for a while - especially if I turn the power off and on. But - its back today. Re: Pump - Underground Water Tank - Noises ? 3May 13, 2017 1:41 pm It sounds like an external pump. An insect invasion maybe? EDIT: https://www.clickenergy.com.au/news-blo ... cted-ants/ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Pump - Underground Water Tank - Noises ? 4May 14, 2017 7:56 am Thanks SH2O ... I think ... Might open the box up and have a look. Re: Pump - Underground Water Tank - Noises ? 5May 14, 2017 11:21 am Ants can be a problem with outdoor electrical equipment. With the symptoms described, the pump's capacitor would be the next check. They are easy to remove, check and also cheap to replace. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Pump - Underground Water Tank - Noises ? 6May 15, 2017 10:51 am Its actually coming from this little cylindrical thingo - with two thin wires. Just above main pump. About 4-5cms long. and only so thick. Re: Pump - Underground Water Tank - Noises ? 7May 15, 2017 12:47 pm Sounds like the capacitor alright. There should be plenty of information on You Tube showing how to remove and check it. You can't go wrong when installing a new capacitor, just make sure you are sold the correct one. It will cost about $25. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Pump - Underground Water Tank - Noises ? 9May 18, 2017 9:56 am I've now realised its the solenoid. The clicking is intermittent - ie goes off for some time. But - will still need to fix. Not sure why the thing clicks - but it might be pressure from full tank ? Will post outcome. Re: Pump - Underground Water Tank - Noises ? 10May 18, 2017 7:15 pm What solenoid is that? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Pump - Underground Water Tank - Noises ? 11May 19, 2017 7:18 am Its above pipe and connects the power to the man bit. Looks a bit like this - screws in. http://www.irrigationstore.com.au/Library/Image/Valves/solenoid.jpg The black bit - with the two wires. Re: Pump - Underground Water Tank - Noises ? 12May 19, 2017 8:32 am It's hard to visualise your setup but it's good that you traced the source of the noise. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Pump - Underground Water Tank - Noises ? 13May 19, 2017 10:05 am Yes - its a funny set-up. U/g tank - with equipment on side of house. Not the usual type I gather. AND - not like the "plastic" above ground tanks either - as I understand it. Re: Pump - Underground Water Tank - Noises ? 14May 19, 2017 11:13 am Did you have it installed or was it pre-existing? Is the solenoid part of a mains water switching device that switches from tank water to mains water when the tank's water level is low? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Pump - Underground Water Tank - Noises ? 15May 19, 2017 11:28 am It was part of the deal - with land. Connected to house at build for toilets etc etc. Yes - it does switch to mains when low. Only ever happened once in the past 5 years. But - yes - it is part of that set-up. It screws into the system. It has proven very useful - excellent pressure from pump - better than mains. I use it for gardens too. Funny - I've never really looked inside the main "box" but there's a "reserve" battery - apparently I'm meant to replace it every few years ... In case of blackouts I guess. So I have done this now ... Will do it from now on when I do the smoke detectors. Re: Pump - Underground Water Tank - Noises ? 16May 20, 2017 10:38 am Hi H2O - found a solenoid - seems to be OK. 2W NC 12-15 etc - 24 V - looks the same. Anything I should look out for. If I put the wrong one in what could happen ? Also - why does it click - and then not click. It might click for a few hours - then not for a similar time. Re: Pump - Underground Water Tank - Noises ? 17May 20, 2017 5:45 pm Solenoids are not in my area of expertise, sorry. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4461 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17540 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10834 |
