Browse Forums Outdoor Living 1 Apr 21, 2020 5:10 pm For the under construction house, Alfresco is about 2.2m wide and 5.5m long. Pic attached. There are 3 Brick Peirs on the longer sude blocking the view from Family and also making the Alfresco looks very narrow. What can we do about it? Is it worth tearing these piers down to put Metal pillars? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Alfresco - Brick piers 2May 01, 2020 4:28 pm You could remove the centre pier and replace the beam/lintel with a larger unit that has the specification to span the entire opening. IMO, metal posts would look like a cheap add on/afterthought and not match the intended style. I may be comparing Apples with Oranges but piers for my slab were much cheaper than this. Not sure, if the ones used for retaining walls would be any different. 6 1163 Piers should have been inspected prior to the slab construction. 3 875 ![]() Thanks the welcome.. so exciting to be an empowered OB. I have yesterday sent a bullet point detailed list of concerns to the Engineer.. as clear as possible. To their… 2 1164 ![]() |
