Browse Forums Outdoor Living 1 Mar 29, 2018 8:51 pm Hi, We are in the process of renovating an outdoor entertaining area. It is an old shed with 1 wall knocked down. I am really bad at design so am after some ideas for what to clad the 3 walls with. At the moment it has corrugated iron walls that look a bit worse for ware.So we plan to cover the walls with something to make it look better and a bit more modern. Anyone have any great ideas for covering the old walls without breaking the bank? Thanks Re: outdoor room cladding ideas 2Mar 30, 2018 9:15 am cupcake.girl Welcome to the forum Great topic! refurbishments are running HOT at the moment Photos help...(Here is an example this is what an expert sees in a photo.. please note it also helps others) "Get The Most From Your Post photos do help" Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12046 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11117 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5643 |
