Browse Forums Outdoor Living 1 Sep 26, 2017 5:07 pm One of those things I'm kicking myself for not giving more thought to earlier and including on my plans. What options are there/how do I go about creating a waterproof structure for my BBQ to sit up against under the alfresco roof? Area in question is 2.4w x 2.7h. So far my ideas- -Louvres, deck to ceiling. Will enable me to always keep bottom half closed. Quote $3.5k! -Cafe blind installed pole to pole. Downside, would like it to be retractable from the top as we will always want the bottom half covered to protect BBQ and cabinets. We are not very handy although I imagine building a small timber frame and putting some FC sheeting couldn't be that hard. How could we then finish off the back of it so it is a bit easier on the eye? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Waterproof area for BBQ? 2Sep 26, 2017 6:35 pm 'Granosite' the sheet. There are textured paints that you can use. Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Waterproof area for BBQ? 3Sep 26, 2017 10:03 pm What about using sheets of colour bond on the back of the bench and having louvres from bench height up? Re: Waterproof area for BBQ? 4Sep 27, 2017 7:34 am Thanks you both M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Waterproof area for BBQ? 5Sep 27, 2017 10:08 am MrsJM What options are there/how do I go about creating a waterproof structure for my BBQ to sit up against under the alfresco roof? How could we then finish off the back of it so it is a bit easier on the eye? Would you be using the b-b-q when it is raining? If you are only looking to protect the b-b-q from the elements and for aesthetic considerations, you could buy a nice cover for it. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Waterproof area for BBQ? 7Sep 27, 2017 4:56 pm Althom What's going to happen to your alfresco ceiling if you use the BBQ in there? It's a 2.7 ceiling. And figures the cross breeze and existing ventilation will be sufficient. I've heard so many arguments for and against rangehoods outside. I don't know to be honest. Happy to hear your thoughts! M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Waterproof area for BBQ? 8Sep 27, 2017 4:58 pm SaveH2O MrsJM What options are there/how do I go about creating a waterproof structure for my BBQ to sit up against under the alfresco roof? How could we then finish off the back of it so it is a bit easier on the eye? Would you be using the b-b-q when it is raining? If you are only looking to protect the b-b-q from the elements and for aesthetic considerations, you could buy a nice cover for it. Good point, and you would think no- I have an uncanny habit of planning events in rain- so would be nice to be able to be protected. Other issue is the outdoor kitchen I've looked at needs electricity due to rotisserie and lights in the BBQ, and it's pretty open at the back unfortunately. Silly really! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Waterproof area for BBQ? 9Sep 27, 2017 5:38 pm MrsJM Althom What's going to happen to your alfresco ceiling if you use the BBQ in there? It's a 2.7 ceiling. And figures the cross breeze and existing ventilation will be sufficient. I've heard so many arguments for and against rangehoods outside. I don't know to be honest. Happy to hear your thoughts! We've also got 2.7m ceilings in our alfresco but it's enclosed on 2 walls You may be right if you stick with the open plan you've got but if you do go with that outdoor kitchen you're going to need to protect it from the weather. Personally I would always now put an outdoor rangehood in. As long as you go for a genuine outdoor model it won't be any more difficult to look after than a standard kitchen one. In fact probably easier because they are more robust This is the one we put in http://www.schweigen.com.au/products/ou ... 0mm-silent with twin external fans. Quieter than our kitchen unit and works a treat CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16562 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11035 Hi We have finally decided to complete a KDR on our corner plot in NE Melbourne suburbs. Given its a corner plot approx. 400 sqm just a standard design may not fit the… 0 8568 |
