Browse Forums Outdoor Living 1 Jul 23, 2017 9:16 pm Hi all, I need to build a few ladder type stair cases outdoors. It will be to allow stairs over rocks as well as one set rising approximately 3 .metres. The 3 metre one will be immersed in water bottom 10cm or so whilst tide i high. The house is build on a steep block and the path leads to water. My question though is regarding the wood. Should I use 100mm x 50mm or 100m x 25mm for the sides of the ladder stairs? I plan to use H4 Treated Pine for all the structure and stairs. The small stairs that I use wound need to worry about the water. Thanks 2 2121 I'm curious, did they provide any reason why they did not like the idea? 1 2510 I’m curious about how you went with this. We are planning a KDRB and considering Plantation Homes as a builder. I’m aware that after the demolition another soil test… 1 6323 |
