Browse Forums Outdoor Living 1 Sep 20, 2016 8:03 pm Hello all While purchasing an outback at Stratco I had a rush of blood and got them to add the pro-beam sub floor, 4 x 3m. It has since arrived and I have put it together which was easy. Now that it's in place I have some concerns. 1. They tell me that no posts are needed and that the outback posts will hold the subfloor up. Doesnt seem right but they should know more than me? 2. The span between the beams are about 552mm which I am pretty sure is too wide unless I use a thicker decking board. Is this right? Any guidance on this would be great. Thanks in advance AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6278 4 14463 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10973 |
