Browse Forums Outdoor Living 1 Nov 22, 2015 2:07 pm I have a 3x3m garden shed in colorbond. The sheets have been fastened together by rivets. The bottom of the shed is rusted away as it's older than 27 years. I want to install a new shed and need to remove this one. What is the best way to remove the rivets? Can I just drill through them? Re: Removing Colorbond Garden Shed 2Nov 22, 2015 3:22 pm Hubby said to drill the head with a drill slightly bigger than the original hole and the head should fall off. 6 11153 The best advice is for you to get a competent building consultant to guide you through your build 7 4689 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4899 |
