Browse Forums Outdoor Living 1 Nov 05, 2015 6:13 pm Re: Artificial turfing and drain vents 2Nov 05, 2015 10:37 pm It's an I O , so that should you have any drainage blockages, a plumbing can get in to the system and flush or hook the blockage out. You'll just have to turf up to it. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Artificial turfing and drain vents 4Nov 06, 2015 9:06 am Stuward Thanks Bpratt. Is there a new top that you can exchange for the ugly concrete one ? I'm not a plumber, but I don't think you get a choice. Perhaps painting the concrete white or green might be an option for you ? Don't know the legalities of simply covering it over, and I mean just barely just covering it with your artificial turf. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Artificial turfing and drain vents 5Nov 06, 2015 10:23 am The plastic (PVC) component is a bolted trap for inspecting either a sewer or DWV line. The concrete component is a surround for said trap. What you want is a stainless steel bolted trap surround. Re: Artificial turfing and drain vents 7Nov 09, 2015 1:38 pm Stuward Thanks Adam I'm a total DIY noob, are these easy to take off and reinstall ? Try and pull up (even distribution) while twisting (anti-clockwise). They are usually screw-on, or just sitting there, but if there is no rotational movement, then it's glued on. You will have to cut below the concrete line, attach a new segment and cap it off. It's not hard at all, but you do need a saw of some type and some PVC glue ($5 for a small container). The new, stainless steel cap can be bought at Reece plumbing for $20. retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 13773 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8465 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4535 |
