Browse Forums Outdoor Living 1 Aug 09, 2004 1:51 pm We bought an ex Hunter Valley wine barrel with the intention of creating a water feature in the garden ie cut in half and have water circulating from one to the other with fish and water plants etc. However so far the sides of the barrels quickly get covered in a slime - sort of jellyish growth. I assume the wine residue impregnated in the timber makes for a great environment for such growth. Anyone have any ideas on how to stop it growing. Obviously with the desire to have fish and plants the solution needs to be envitronmentally friendly. Thanks in advance. Re: Slime in wine barrels used as water features 2Dec 09, 2004 10:35 am Barrels are made from wood and problems are often encountered when filling directly with water. Also if you intend to keep fish or plant stock the chemicals already deep in the timber can cause problems. The solution to this is to buy a barrel liner or pond liner. This will stop chemical reactions between the timber and water.
I suggest you go and take a look at www.waterfeaturesonline.com.au as there are articles galore on how to create barrel water features. Just do a search on 'barrel' on the article page. The Pond Shop on this site also has barrels, polycarbonate barrel liners and pond liner for sale for delivery anwhere in australia. It's Simple....Just Add Water! Re: Slime in wine barrels used as water features 3Dec 10, 2004 8:43 am DrPond,
Thanks for your wonderful advice, and welcome to the homeone.com.au's forum. Jason. Re: Slime in wine barrels used as water features 5May 31, 2007 11:44 am Interpet Feature Clear works exceptionally well with slime in waterfeatures. It's cheap and if you follow the dosage it works perfectly. As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17787 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18280 18 90414 |
