Browse Forums Outdoor Living 1 Jun 24, 2015 11:51 am HI, I am after some advice and guidance on how to build a timber framed corrugated fence. I am wanting to use large posts such as 150 x 150 or 200 x 200, and have a mini orb or similar metal panel in the middle. With the ribs though, i want them running horizontally, and i dont want to have a rail in the middle if possible. I have seen the pre-made fence panels, but the ribs all run vertically. Is there way that I can make this type of fence without a middle rail? The fence only needs to be around 1.6m high as well. I considered using a middle rail, but putting the corrugated sheets on either side, but thought this might seem a bit wasteful. any advice would be greatly appreciated. Thanks Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4921 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20963 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16001 |
