Browse Forums Outdoor Living Re: Surface Water Drainage/Mould Inside Brickwork Subfloor H 2Apr 03, 2015 5:59 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Surface Water Drainage/Mould Inside Brickwork Subfloor H 4Apr 03, 2015 10:10 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Surface Water Drainage/Mould Inside Brickwork Subfloor H 6Apr 04, 2015 6:52 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Surface Water Drainage/Mould Inside Brickwork Subfloor H 7Apr 29, 2015 12:47 am My apologies for not getting back to you sooner, as I hadn't received any emails saying that someone had replied to my post. All fixed now!!! Thanks again for the great advice. I already had a building inspector come and see me on the first inspection, so would you charge for working on a single problem, or charge for the entire fee? I also had another hitch in my master plan, to build a deck all the way around (which I could then just dig up around the house, and leave it to air for good - by your excellent advice, but after asking council about permits, it would be estimated at over $2,500!!! I estimated the materials about that much, so I guess the deck is out!! Another quick question, was that would I be able to raise existing pavers, which are already on compacted sand/soil, by just adding 50-100mm of additional sand underneath each paver and re-laying, or would I have to take all the sand out, and add more to the base (which will kill me). Thanks again in advance, This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28319 Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4064 XCEM Alpha flooring seems to relatively new and I could not found any reviews. Have you or someone you know have used it and would recommend over other subfloor options?… 2 7588 |
