Browse Forums Outdoor Living 1 Jan 26, 2015 9:29 am Hi All, I'm new to this forum so I'll be able to tap into this wealth of knowledge and someday repay the community. I recently purchased a Gerni Pressure washer and was hosing down the deck to remove a lot of the algae buildup. Future plan is to do a thorough clean with deck + scrub and re-oil as the deck does look tired. I've got two questions I hope the forum can help out with: 1) I believe the deck is some sort of pine, but would anyone have a good idea of what it may be? 2) Whilst hosing, there's 1 plank that deteriorated far more than the others (see pictures). Anyone know why this may be the case? I have some left-over sections that I may be able to replace it with, but if not I'd like to buy a new piece from bunnings. Here's a photo for reference: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Kevin Re: Rear deck cleaning question 2Jan 28, 2015 12:21 pm Can't really tell what kind of timber that is but yeah best to replace that board as it as begun to rot. You can get deck cleaning products or you can make your own using a Napisan solution. Works well on decks to prepare for oiling/staining. Build Thread: viewtopic.php?f=31&t=57639 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 5850 We have a new build and need to clean bricks around a newly constructed deck. Need advice about whether to clean bricks with acid prior to oiling the deck, or should we… 0 1953 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 3617 |
