Browse Forums Outdoor Living 1 Sep 28, 2014 8:16 pm I have to install a tank after the meter with a pressure pump to service the new dwelling (see image) https://www.facebook.com/Vegnoutfarm/ph ... =1&theater I am going to dig the tank into the ground to get maximum flow into it but have a question. It is a top fill type poly tank I need but all the ones I see for sale dont seem to have a top female thread for inflow? Also they dont have a valve system set up to cut the flow when it reaches the top. My specific question is: Do I have to then plumb the meter side into the very top of the tank through one of the lids? Also, do i have to setup a custom float system? Are there not tanks that already have the threaded inlet at the top and accessory float systems that fit straight onto the tanks they come with? DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31371 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17417 Thanks for letting us know. The programmer will have a look at this later today. 2 6772 |
