Browse Forums Outdoor Living 1 May 19, 2014 11:57 am So we've had liquid limestone outside for about 3 years now, and it's been great. However it's started to get quite dirty and could probably use a good clean and seal. What is the best product to clean with? And what is an easy product to seal it with once i'm done? It's held up quite well, however there is one or two really fine hairline cracks – is there anything I can 'putty' these up with? Re: Cleaning and Sealing Liquid Limestone 2May 30, 2014 11:38 am We had liquid limestone previously. We cleaned it each spring with high pressure water (gurney). As for sealing it was sealed by installers, but the seal is always uneven due to porosity of the natural product. So I imagine it's not easy to get an even seal. Re: Cleaning and Sealing Liquid Limestone 3May 30, 2014 12:12 pm What is "liquid" limestone ? We have limestone pavers ... Re: Cleaning and Sealing Liquid Limestone 4May 30, 2014 12:50 pm It's pumped in or barrowed in from a cement truck. Reconstituted and actual limestone. Lines are cut in it after it's cured. Re: Cleaning and Sealing Liquid Limestone 5May 30, 2014 3:50 pm Treeseachanger It's pumped in or barrowed in from a cement truck. Reconstituted and actual limestone. Lines are cut in it after it's cured. Oh. Sounds a good idea. Thanks TSC. Re: Cleaning and Sealing Liquid Limestone 6May 30, 2014 10:03 pm Treeseachanger We had liquid limestone previously. We cleaned it each spring with high pressure water (gurney). As for sealing it was sealed by installers, but the seal is always uneven due to porosity of the natural product. So I imagine it's not easy to get an even seal. Cleaning it seems not too bad - used a pressure cleaner to try it. Works ok, but feels like we're moving dirt from one part to another. Was sealed by the installers, but was told it needs to be re-sealed every few years. Just can't work out what I use to re-seal it. Re: Cleaning and Sealing Liquid Limestone 7May 30, 2014 10:27 pm I'm sure the installers will tell you what they used? Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6700 We have a new build and need to clean bricks around a newly constructed deck. Need advice about whether to clean bricks with acid prior to oiling the deck, or should we… 0 2582 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4923 |
