Browse Forums Outdoor Living 1 Apr 09, 2014 11:31 am Hi All, Q. we are doing a KDR. we have a outdoor alfresco area. The area is limited. width of 2.03 metres less 470mm for the brick pillar. leaves us just 1.56 Metres we were thinking of shrinking the kitchen by .5 metre allowing us a space of 2.06 for an outdoor kitchen. checking the outdoor kitchens. the smallest is 2.10m wide for a modular version. Has anyone done a custom outdoor kitchen to fit such a small space in sydney want a 4 burner bbq + side burner, and a small bench. Alternative is do a corner outdoor bbq at a right angle with the brick pillar in the corner. bbq and side burner on the side and around the corner sink and benchtop? thanks ugly99 Re: outdoor kitchen limited space ideas 2Apr 10, 2014 8:58 am does your kitchen back into this area? Maybe a servery (accordian) window to combine the areas? "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3582 dimensions on your original plan are inconsistent and with accurate dimensions (including site plan, upstairs and down) i could make a proper scale drawing with furniture… 3 7518 |
