Browse Forums Outdoor Living 1 Nov 15, 2013 4:09 pm Hey All Just need some guidance I'm will be doing my own decking around the front porch and alfresco area once the house is built.. Lots of info on the internet and youtube, so pretty confident I can do this myself. Anyone have any ideas on how to do the cedar lining on the roof? There's hardly any info on the net on how to do this. Would anyone know where is the best place to start? The house just comes standard with plasterboard roof around the alfresco area, I may even think about doing it around the front porch I'm assuming the Cedar lining will need to be screwed on to some battens. Does that mean you have to remove the ceiling plaster around the alfresco area to do this?? Re: Cedar Lining around Alfresco Area - Should I attempt ?? 2Nov 30, 2013 10:18 pm Firstly, cedar is a great choice of finish! The cedar boards will need to be fixed direct to battens via nail fixing but can be done with screw fixings. You could overlay new battens on top of the plasterboard as long as you fixed back to the original battens, however I would strongly recommend that you remove the plasterboard and fix he new cedar boards to the original battens/rafter. Depending on the direction of the new boards you may need to introduce counter battens. Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3424 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13663 There are a lot of private inspectors should have stayed working as tradies!! Firstly, you paid for a professional opinion of the works, if he has picked up on an item he… 1 2039 |
