Browse Forums Outdoor Living 1 Aug 23, 2013 1:41 pm Hey Guys, We currently have an alfresco that is tiled (cement slab underneath) and we are looking to extend from the alfresco out and down the side of the house, we want it to flow without a step up or step down, wanting to know what our options are - what will work the best - I was thinking of trying to get the a slab done and tile it the same but worried it might not cross smoothly, would a timber deck be a better option?? Also what is more cost effective? Pro's & Con's, it's our first house we built with a house & land package so they wouldn't extend it in the first place Thanks guys! Re: Alfresco extension! Need Help! 2Aug 23, 2013 7:15 pm Timber deck will work out best if the current floor level is more than 400 from the ground, otherwise concrete slab will be most economical Good Luck @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Alfresco extension! Need Help! 3Aug 25, 2013 8:47 am Difficult one. You may never get the tiles to match up - or even up. Unless you get identical ones - if you can. My tip - get a good paver who has a concrete person - ie don't use separate people. Steps are good - but can cause trips etc. I'd go flat with a slope of course. Not sure where you are - but if you have a pest strip etc you may need to extend it. And - if you can't match tiles - maybe try a pattern that looks like you meant to make it different ... Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4168 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 4843 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1606 |
