Browse Forums Outdoor Living Re: Retaining perth 2Apr 20, 2013 1:12 pm Try this guy , does a good job Bobby 0421 469 277. Bonita Stone Paving Products http://www.bonitastone.com.au Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16142 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6903 Not sure what council area you are in. Some LGA's allow zero lot retaining walls. This usually occurs in greenfield developments but not often in established areas. You… 1 8235 |
