Browse Forums Outdoor Living 1 Mar 13, 2013 12:07 pm Hi Everyine, Just wondering if someone can help me with a question about paving. We have an area in our backyard adbout 7m x 3.5 that is currently lilydale toppings on quite compacted hard groun, I think concrete in some areas. We want to pave the area instead, do we have to dig out the lilydale toppings or can we pave over the top? TIA Re: Question regarding paving? 2Mar 20, 2013 3:32 pm Hi there! What you are after is a hard base of which the lilydale topping you described is spot on. You might want to consider hiring a compactor and spreading a thin layer of B grade crush rock (road base) to further compact the ground. You can also use the crushed rock to level out any unevenness. Once you have a hard base, drop a 20mm layer of premium washed sand. Either make sure the sand is dry for maximum compactness or compact the wet sand with a flat surface. Place your pavers over that. Hopefully that helps! i would not be signing anything on the day read your contract about when builder submits final invoice generally, have to meet builder within 7 days of receiving final… 1 4735 Hi All, Recently we have signed a contract with Burbank and we are not aware that they have just DORSET, SURREY, HAMPSHIRE, KENT, PILBARA and REDGUM bricks from PGH are… 0 3152 Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 3259 |
