Browse Forums Outdoor Living 1 Jan 26, 2013 3:47 pm Patio tiling issue - any advice? Hi, I'm hoping there might be a tiler or two out there who can offer advice, as my handyman partner decided to tile our 14m2 verandah/patio area, and while he has basically done a good job, he has run into problems with finishing it off. He laid the tiles using the house wall as the starting point, but the raised concrete verandah is not square, and so we are left with a tapering gap at the edge of the concrete, at one end of the verandah is it less than 1mm, and at the other it is around 20mm. I dont think we can use cut tiles as this will just accentuate the sloping edge, is there any aluminium strip that we could use to cover the whole edge along the length of the verandah, and if so would it look strange? Any suggestions of solutions would be most appreciated. Re: Patio tiling issue - any advice? 2Jan 26, 2013 4:39 pm Perhaps a piece of timber - painted or stained - same size - ie not tapered - to give it a "border/margin" look ? One piece I mean. It would mean a slight lift in the level - so a potential "trip" I guess. We accidentally burnt the top of our kitchen bench one time. Instead of replacing the whole top we just cut a rectangle around the burn - put in a non-clear thick glass piece - surrounded by metal frame - held down by clamps under the bench - and used it as a chopping board. Everyone says what a great idea - not knowing it was caused by the burn ... So the wooden frame may turn out to be the thing that sets off the patio ... Re: Patio tiling issue - any advice? 3Mar 04, 2013 12:35 am Thanks St Mike, I think your suggestion of timber would look much better than some type of metal which is what I had originally thought (- like the strips they sometimes put between carpet and tiles). Im not sure if I can buy something purpose built or if Id have to devise something.... DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8988 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16159 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7793 |
