Browse Forums Outdoor Living Re: Deck steps over a concrete slab ramp 7Nov 21, 2012 10:42 am Hi. I've got the bolt-down brackets from Doyles in Mitchelton, QLD. I bought around 90 so I got a much better price. Also check with http://www.scrooz.com.au/ as I was told they were adding a new product line of brackets and stirrups. I found the brackets hard to find as I needed they not to be more than 130mm high and the Pryda ones are more than that. Re: Deck steps over a concrete slab ramp 8Nov 21, 2012 10:47 am jedaking Where can i buy the "" The green shed stock galvanised c shape brackets"? Thanks Bunnings.. Check this thread viewtopic.php?f=17&t=59821 Deck steps over a concrete slab ramp 10Nov 22, 2012 9:18 pm Leave the ramp & simply deck it on the angle. We had ramps installed beside steps for disability access . The steps ended up shoe rack as everyone used the ramp. Eventually we got rid of the steps all together. A ramp is easier for everyone. Re: Deck steps over a concrete slab ramp 11Nov 23, 2012 10:27 am wheeliworks Leave the ramp & simply deck it on the angle. We had ramps installed beside steps for disability access . The steps ended up shoe rack as everyone used the ramp. Eventually we got rid of the steps all together. A ramp is easier for everyone. That would be much simpler... I'll think about it (aka, ask the wife ) Following these simple steps will help you mitigate unwanted costs, have your expectations met and give… 0 4068 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 5208 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 4661 |
